Salta al contenuto principale
Lenovo Thinkpad Tablet 1838 Speaker Replacement
Cosa ti serve
  1. Lenovo Thinkpad Tablet 1838 Speaker Replacement, Speaker: passo 1, immagine 1 di 1
    • Remove the middle button by putting a plastic spudger or your fingernail underneath the button and lifting up.
  2. Lenovo Thinkpad Tablet 1838 Speaker Replacement: passo 2, immagine 1 di 1
    • There will be two screws under the button you have removed. Use your Phillips #00 Screwdriver to remove these screws.
  3. Lenovo Thinkpad Tablet 1838 Speaker Replacement: passo 3, immagine 1 di 1
    • With a plastic spudger or your fingernail, find the seam where the front and back panel connect and pry open from the bottom. After making a small opening, go around the device counter-clockwise.
  4. Lenovo Thinkpad Tablet 1838 Speaker Replacement: passo 4, immagine 1 di 1
    • Before you separate the panels, there is a ribbon cable connecting the LCD to the motherboard. To avoid damage of the ribbon cable, lift the panel with the LCD from right to left like opening a book.
  5. Lenovo Thinkpad Tablet 1838 Speaker Replacement: passo 5, immagine 1 di 2 Lenovo Thinkpad Tablet 1838 Speaker Replacement: passo 5, immagine 2 di 2
    • This is the speaker unit, and is being held by a screw. Use a Phillips #00 Screwdriver to remove the screw indicated by the red circle in the second image.
  6. Lenovo Thinkpad Tablet 1838 Speaker Replacement: passo 6, immagine 1 di 2 Lenovo Thinkpad Tablet 1838 Speaker Replacement: passo 6, immagine 2 di 2
    • The speaker is still connected to the motherboard by a little connector. Using a plastic spudger or your fingernail, pry the connector to the direction marked by the two red arrows in the second image.
  7. Lenovo Thinkpad Tablet 1838 Speaker Replacement: passo 7, immagine 1 di 1
    • After removing the connector, you can now remove the speaker. Use your spudger or fingernail to lift the speaker up. The speaker should come out easily.
Conclusione
Arturo Barboza
Membro da: 10/26/17
209 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 151
