Salta al contenuto principale
Lenovo Thinkpad Tablet 1838 Button Replacement
Cosa ti serve
  1. Lenovo Thinkpad Tablet 1838 Button Replacement, Button: passo 1, immagine 1 di 1
    • Remove the button on the front of the tablet that has the arrow pointing to the left .
    • You can do this by putting your fingernail or a Spudger underneath the button and pulling up.
  2. Lenovo Thinkpad Tablet 1838 Button Replacement: passo 2, immagine 1 di 1
    • Remove the 2 screws found under the button you just removed with a size #00 Philips Head Screwdriver.
  3. Lenovo Thinkpad Tablet 1838 Button Replacement: passo 3, immagine 1 di 1
    • Use a plastic spudger to pry open the screen from the tablet.
    • Work around the perimeter of the tablet going counter-clockwise.
  4. Lenovo Thinkpad Tablet 1838 Button Replacement: passo 4, immagine 1 di 1
    • Open the tablet screen to the left. (Like opening a book) Making sure not to disconnect any of the wires connecting the screen and tablet.
  5. Lenovo Thinkpad Tablet 1838 Button Replacement: passo 5, immagine 1 di 1
    • To peel back the ribbon connector, first gently open the white gates.
    • You can do this with a plastic Spudger or your fingernail.
  6. Lenovo Thinkpad Tablet 1838 Button Replacement: passo 6, immagine 1 di 1
    • Remove the screw that is highlighted.
    • Use a size #00 Philips head screwdriver.
  7. Lenovo Thinkpad Tablet 1838 Button Replacement: passo 7, immagine 1 di 1
    • Remove the blue motherboard the screw was attached to.
    • Make sure to remove it carefully, so you do not accidentally damage the surrounding parts.
  8. Lenovo Thinkpad Tablet 1838 Button Replacement: passo 8, immagine 1 di 3 Lenovo Thinkpad Tablet 1838 Button Replacement: passo 8, immagine 2 di 3 Lenovo Thinkpad Tablet 1838 Button Replacement: passo 8, immagine 3 di 3
    • To remove the buttons, you need to push the little black tabs towards each other with either your fingernails or plastic spudger.
    • While the tabs are pushed in the buttons should pop out.
Conclusione
Dylan Coleman
Membro da: 09/21/18
157 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 349
