Salta al contenuto principale
Lenovo Thinkpad T450s RAM Replacement
Cosa ti serve
  1. Lenovo Thinkpad T450s RAM Replacement, Battery: passo 1, immagine 1 di 2 Lenovo Thinkpad T450s RAM Replacement, Battery: passo 1, immagine 2 di 2
    • Turn off device before starting
    • Flip the laptop upside down so you have access to the battery.
  2. Lenovo Thinkpad T450s RAM Replacement: passo 2, immagine 1 di 1
    • Slide lock button 1 to the unlock position and gently slide away from your body.
  3. Lenovo Thinkpad T450s RAM Replacement: passo 3, immagine 1 di 2 Lenovo Thinkpad T450s RAM Replacement: passo 3, immagine 2 di 2
    • Slide lock button 2 to the unlock position and continue gently sliding until the battery is removed.
  4. Lenovo Thinkpad T450s RAM Replacement, Lenovo Thinkpad T450s Bottom Panel Removal: passo 4, immagine 1 di 3 Lenovo Thinkpad T450s RAM Replacement, Lenovo Thinkpad T450s Bottom Panel Removal: passo 4, immagine 2 di 3 Lenovo Thinkpad T450s RAM Replacement, Lenovo Thinkpad T450s Bottom Panel Removal: passo 4, immagine 3 di 3
    • Flip the device over and lay it down with the underside facing upwards.
    • Unscrew all 8 screws. While they should not come out completely, in some cases, the plastic retaining washers may come off of one or more of the screws, allowing them to come out completely. - should this happen, look for a loose, tiny black plastic washer once the case is open. It's possible, in some cases, to reattach the retaining washer.
  5. Lenovo Thinkpad T450s RAM Replacement: passo 5, immagine 1 di 2 Lenovo Thinkpad T450s RAM Replacement: passo 5, immagine 2 di 2
    • Pry the bottom from the computer until it pops out.
    • In some cases, the vented side of the case may cling to the heat sink; appears to be adhesive. Take care when separating.
  6. Lenovo Thinkpad T450s RAM Replacement, RAM: passo 6, immagine 1 di 3 Lenovo Thinkpad T450s RAM Replacement, RAM: passo 6, immagine 2 di 3 Lenovo Thinkpad T450s RAM Replacement, RAM: passo 6, immagine 3 di 3
    • Pull one side of the prong that is holding the RAM in place
  7. Lenovo Thinkpad T450s RAM Replacement: passo 7, immagine 1 di 1
    • Pull the other side prong until the RAM pops up.
  8. Lenovo Thinkpad T450s RAM Replacement: passo 8, immagine 1 di 2 Lenovo Thinkpad T450s RAM Replacement: passo 8, immagine 2 di 2
    • Pull the RAM out of the device
Conclusione
Un commento
My t450s comes with an internal battery. The comment on this guide records the process for disabling the internal battery temporarily.
I also used this guide from Lenovo as I found removing the back plate rather difficult.
ray beats - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 50
Tutti i Tempi: 4,654
