Salta al contenuto principale
Lenovo Thinkpad T450s Bottom Panel Removal
Cosa ti serve
  1. Lenovo Thinkpad T450s Bottom Panel Removal, Battery: passo 1, immagine 1 di 2 Lenovo Thinkpad T450s Bottom Panel Removal, Battery: passo 1, immagine 2 di 2
    • Turn off device before starting
    • Flip the laptop upside down so you have access to the battery.
  2. Lenovo Thinkpad T450s Bottom Panel Removal: passo 2, immagine 1 di 1
    • Slide lock button 1 to the unlock position and gently slide away from your body.
  3. Lenovo Thinkpad T450s Bottom Panel Removal: passo 3, immagine 1 di 2 Lenovo Thinkpad T450s Bottom Panel Removal: passo 3, immagine 2 di 2
    • Slide lock button 2 to the unlock position and continue gently sliding until the battery is removed.
  4. Lenovo Thinkpad T450s Bottom Panel Removal, Lenovo Thinkpad T450s Bottom Panel Removal: passo 4, immagine 1 di 3 Lenovo Thinkpad T450s Bottom Panel Removal, Lenovo Thinkpad T450s Bottom Panel Removal: passo 4, immagine 2 di 3 Lenovo Thinkpad T450s Bottom Panel Removal, Lenovo Thinkpad T450s Bottom Panel Removal: passo 4, immagine 3 di 3
    • Flip the device over and lay it down with the underside facing upwards.
    • Unscrew all 8 screws. While they should not come out completely, in some cases, the plastic retaining washers may come off of one or more of the screws, allowing them to come out completely. - should this happen, look for a loose, tiny black plastic washer once the case is open. It's possible, in some cases, to reattach the retaining washer.
  5. Lenovo Thinkpad T450s Bottom Panel Removal: passo 5, immagine 1 di 2 Lenovo Thinkpad T450s Bottom Panel Removal: passo 5, immagine 2 di 2
    • Pry the bottom from the computer until it pops out.
    • In some cases, the vented side of the case may cling to the heat sink; appears to be adhesive. Take care when separating.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 34
Tutti i Tempi: 3,696
