Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
If the LCD screen of your Lenovo ThinkPad T410i is broken or you wish to install a new screen, this guide will show you how to replace and reinstall the screen.
Guide notes
  • This guide is hardware only, and it would not help resolve issues such as screen staying black or screen not responding to input.
  • Unplug the system from the power source (if it is plugged in), and remove the battery before you perform any of the steps.
  • Once you install the new LCD screen, safely dispose the old one.
  1. Use a spudger to remove the plastic covers from the LCD screen. Use a spudger to remove the plastic covers from the LCD screen.
    • Use a spudger to remove the plastic covers from the LCD screen.
  2. Remove the two 6.0mm screws on each side using Philips #0 head screwdriver as shown in the picture.
    • Remove the two 6.0mm screws on each side using Philips #0 head screwdriver as shown in the picture.
  3. Use a spudger to separate the bezel of the LCD screen.
    • Use a spudger to separate the bezel of the LCD screen.
  4. Kit cacciaviti Manta
    112 punte per ogni riparazione.
    Upgrade Your Toolbox
  5. Continue along the edges lifting up and prying off the plastic LCD bezel. Continue along the edges lifting up and prying off the plastic LCD bezel. Continue along the edges lifting up and prying off the plastic LCD bezel.
    • Continue along the edges lifting up and prying off the plastic LCD bezel.
  6. Use a Philips #0 head screwdriver to remove the two 6.0mm screws from the top corners of the LCD screen. Use a Philips #0 head screwdriver to remove the two 6.0mm screws from the top corners of the LCD screen.
    • Use a Philips #0 head screwdriver to remove the two 6.0mm screws from the top corners of the LCD screen.
  7. Place the LCD screen safely down on its front. Pulling the screen too far away from the screen may damage delicate ribbon cable. Peel the tape off the ribbon cable's contacts.
    • Place the LCD screen safely down on its front.
    • Pulling the screen too far away from the screen may damage delicate ribbon cable.
    • Peel the tape off the ribbon cable's contacts.
    • Carefully detach the ribbon cable from the LCD screen.
    • Poking the golden contacts may easily damage them.
  8. Remove the screen from your device.
    • Remove the screen from your device.
Conclusione
Altre 3 persone hanno completato questa guida.
Harsh Patel
Membro da: 02/10/2017
287 Reputazione
2 Guide realizzate
USF Tampa, Team S1-G2, Thompson Fall 2017 Membro di USF Tampa, Team S1-G2, Thompson Fall 2017
USFT-THOMPSON-F17S1G2
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 234
