Salta al contenuto principale
Lenovo Thinkpad T410i Keyboard Replacement
Cosa ti serve
  1. Lenovo Thinkpad T410i Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Remove the battery.
    • Unfortunately, the battery isn't pictured because our device did not come with a battery at the time of the creation of this guide.
  2. Lenovo Thinkpad T410i Keyboard Replacement: passo 2, immagine 1 di 2 Lenovo Thinkpad T410i Keyboard Replacement: passo 2, immagine 2 di 2
    • Loosen (do not remove) the 14.0mm screw in the DIMM slot cover with a Phillips #2 screwdriver.
  3. Lenovo Thinkpad T410i Keyboard Replacement: passo 3, immagine 1 di 1
    • Pry loose the top left key-covers with a plastic opening tool.
  4. Lenovo Thinkpad T410i Keyboard Replacement: passo 4, immagine 1 di 2 Lenovo Thinkpad T410i Keyboard Replacement: passo 4, immagine 2 di 2
    • Nudge the plastic tabs around the keyboard using the plastic opening tool while lifting it with a spudger.
    • Ensure all 5 clips are loosened from the front of the keyboard before removing.
  5. Lenovo Thinkpad T410i Keyboard Replacement: passo 5, immagine 1 di 1
    • Slowly raise keyboard away from the laptop. A short ribbon must be removed before keyboard is free.
    • Remove the keyboard from the device.
Conclusione
Altre 5 persone hanno completato questa guida.
USF Tampa, Team S1-G2, Thompson Fall 2017 Membro di USF Tampa, Team S1-G2, Thompson Fall 2017
USFT-THOMPSON-F17S1G2
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 899
