Introduzione
This guide will show you how to replace your hard drive located in your Lenovo Thinkpad Edge E545.
Hard drive failures will include overheating, major slowdowns, frequent error messages, and missing files or files you cannot open.
Before beginning repair, power off your device and unplug It from the charger. Also check the area around your Thinkpad to keep clear of extra debris that may get in during repair.
Cosa ti serve
Using a Phillips screwdriver, remove the four screws around the edges of the rectangular panel.
After back panel is removed, you can remove the two screws at the bottom of the hard drive using the Phillips #000 screwdriver.
