Salta al contenuto principale
Lenovo Thinkpad Edge E40 RAM Replacement
Cosa ti serve
  1. Lenovo Thinkpad Edge E40 RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Flip your laptop over.
    • Unplug all cables from the computer. If you're just swapping the battery, you can leave the power cord plugged in.
  2. Lenovo Thinkpad Edge E40 RAM Replacement, Battery: passo 2, immagine 1 di 1
    • Pull the locking tab on the battery towards the unlock position.
    • Pull the battery out of the socket.
  3. Lenovo Thinkpad Edge E40 RAM Replacement, Bottom Cover: passo 3, immagine 1 di 1
    • Loosen the following five screws:
    • 5 Phillips #0 screws
    • 1 recessed Phillips #0 screw
    • These screws do not come out all the way, and need to be un-tightened a lot more than you might think.
  4. Lenovo Thinkpad Edge E40 RAM Replacement, Bottom Cover: passo 4, immagine 1 di 1
    • Pull up on the front cover from the left and right sides.
    • Do not force the cover off the laptop. If it does not want to come out, undo the screws a bit more.
  5. Lenovo Thinkpad Edge E40 RAM Replacement, RAM: passo 5, immagine 1 di 2 Lenovo Thinkpad Edge E40 RAM Replacement, RAM: passo 5, immagine 2 di 2
    • Pull the two tabs on the sides of the RAM.
    • Repeat on the second stick.
    • Do not touch the gold contacts on the RAM, because that could easily damage the RAM.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 87
