Salta al contenuto principale
Lenovo ThinkPad Yoga Keyboard Replacement
Cosa ti serve
  1. Lenovo ThinkPad Yoga Keyboard Replacement, Battery: passo 1, immagine 1 di 3 Lenovo ThinkPad Yoga Keyboard Replacement, Battery: passo 1, immagine 2 di 3 Lenovo ThinkPad Yoga Keyboard Replacement, Battery: passo 1, immagine 3 di 3
    • Flip the laptop over so the bottom is facing you.
    • Remove the ten screws using a Phillips #1 screwdriver.
    • Using the plastic opening tool, pry the bottom cover off the laptop.
  2. Lenovo ThinkPad Yoga Keyboard Replacement: passo 2, immagine 1 di 3 Lenovo ThinkPad Yoga Keyboard Replacement: passo 2, immagine 2 di 3 Lenovo ThinkPad Yoga Keyboard Replacement: passo 2, immagine 3 di 3
    • Remove two screws from the battery using a Phillips #1 screwdriver.
    • Disconnect the battery connector from the motherboard.
    • Remove the battery from the laptop.
  3. Lenovo ThinkPad Yoga Keyboard Replacement, Speakers: passo 3, immagine 1 di 3 Lenovo ThinkPad Yoga Keyboard Replacement, Speakers: passo 3, immagine 2 di 3 Lenovo ThinkPad Yoga Keyboard Replacement, Speakers: passo 3, immagine 3 di 3
    • Disconnect connectors. Use fingers to pinch and pull the connector out.
  4. Lenovo ThinkPad Yoga Keyboard Replacement, Fan: passo 4, immagine 1 di 3 Lenovo ThinkPad Yoga Keyboard Replacement, Fan: passo 4, immagine 2 di 3 Lenovo ThinkPad Yoga Keyboard Replacement, Fan: passo 4, immagine 3 di 3
    • Remove the two screws from the retainer for the ports using a Phillips #1 screwdriver.
    • Remove the nine screws from the motherboard using a Phillips #1 screwdriver.
    • Remove the four screws from the fan under the motherboard using a Phillips #1 screwdriver.
    • Remove the fan from the motherboard.
  5. Lenovo ThinkPad Yoga Keyboard Replacement, Keyboard: passo 5, immagine 1 di 1
    • Remove twelve screws from the midframe using a Phillips #1 screwdriver.
  6. Lenovo ThinkPad Yoga Keyboard Replacement: passo 6, immagine 1 di 1
    • Use a spudger to pry open the keyboard panel.
    • Continue to pry until the panel is loose enough to take off.
  7. Lenovo ThinkPad Yoga Keyboard Replacement: passo 7, immagine 1 di 1
    • Remove the keyboard from the laptop.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 12
Ultimi 7 Giorni: 55
Ultimi 30 Giorni: 266
Tutti i Tempi: 7,446
