Salta al contenuto principale
Lenovo ThinkPad Yoga 370 Screen Replacement
Cosa ti serve
  1. Lenovo ThinkPad Yoga 370 Screen Replacement, Screen: passo 1, immagine 1 di 1
    • Remove rubber plugs on the lower corners of the screen
    • Unscrew screws under the rubber plugs
  2. Lenovo ThinkPad Yoga 370 Screen Replacement: passo 2, immagine 1 di 2 Lenovo ThinkPad Yoga 370 Screen Replacement: passo 2, immagine 2 di 2
    • Remove the four 4 mm screws along the bottom of the display.
  3. Lenovo ThinkPad Yoga 370 Screen Replacement: passo 3, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using tweezers, remove the tape from the display cable below the screen.
  4. Lenovo ThinkPad Yoga 370 Screen Replacement: passo 4, immagine 1 di 1
    • Slide the screen downwards towards the keyboard.
    • Lift the screen slowly from the frame when the screen is slid down completely.
    • The screen is still attached to the computer, do not pull away from the laptop frame until a later step.
    • Flip the screen over and lay face down on the keyboard.
  5. Lenovo ThinkPad Yoga 370 Screen Replacement: passo 5, immagine 1 di 3 Lenovo ThinkPad Yoga 370 Screen Replacement: passo 5, immagine 2 di 3 Lenovo ThinkPad Yoga 370 Screen Replacement: passo 5, immagine 3 di 3
    • Peel the tape off from the back of the screen, connecting the display to the device.
    • Remove the screen.
Conclusione
Un commento
I strongly recommend to at least unplug the battery before replacing the screen. I fried a motherboard once by manipulating a screen ribbon while the battery was still plugged in.
You should always unplug the battery before working on a device anyway.
lululock - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 95
Tutti i Tempi: 2,229
