Salta al contenuto principale
Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement
Cosa ti serve
  1. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement, Battery: passo 1, immagine 1 di 1
    • Device needs to be powered off and unplugged.
    • Remove the stylus from the device and set it aside.
  2. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: passo 2, immagine 1 di 2 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: passo 2, immagine 2 di 2
    • Using the Phillips #00 screwdriver unscrew the eight circled 4mm screws until you hear a click.
    • The screws will remain attached to the back cover.
  3. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: passo 3, immagine 1 di 2 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: passo 3, immagine 2 di 2
    • Note that while the screws are undone, the bottom cover is still attached by several plastic clips around the edges.
    • Using the plastic opening tool, work around the edges of the bottom cover to undo the plastic clips.
  4. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: passo 4, immagine 1 di 2 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: passo 4, immagine 2 di 2
    • Gently remove the cover by placing your fingers around the edges.
  5. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: passo 5, immagine 1 di 3 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: passo 5, immagine 2 di 3 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: passo 5, immagine 3 di 3
    • With your fingers, fold back the plastic cover highlighted.
    • Using two fingers, gently remove the battery connectors.
  6. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: passo 6, immagine 1 di 3 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: passo 6, immagine 2 di 3 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: passo 6, immagine 3 di 3
    • Using the Phillips #00 screwdriver, remove the two 4mm screws.
    • Remove the battery.
    • Make sure to only replace with a battery that matches your computer, any other battery could ignite or explode.
  7. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement, Fingerprint Reader: passo 7, immagine 1 di 1
    • Identify the fingerprint reader on the left side of the laptop.
  8. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: passo 8, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • To disconnect the fingerprint reader from the motherboard, unlock the ZIF connector and pull it out using tweezers.
  9. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: passo 9, immagine 1 di 2 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: passo 9, immagine 2 di 2
    • Remove the one 4 mm screw from the metal covering with the Phillips #00 screwdriver.
    • Remove the metal cover.
  10. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: passo 10, immagine 1 di 1
    • Using tweezers, remove the fingerprint reader from the inset.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 24
Tutti i Tempi: 329
