Salta al contenuto principale
Lenovo ThinkPad Yoga 260 Repair RAM Replacement
Cosa ti serve
  1. Lenovo ThinkPad Yoga 260 Repair RAM Replacement, Back Cover: passo 1, immagine 1 di 1
    • Ensure the device is off and unplugged.
    • Remove the stylus from its port and set aside.
  2. Lenovo ThinkPad Yoga 260 Repair RAM Replacement: passo 2, immagine 1 di 2 Lenovo ThinkPad Yoga 260 Repair RAM Replacement: passo 2, immagine 2 di 2
    • Using a Phillips #1 screwdriver, gently unscrew the eight 1.3 mm Phillips #1 screws until you hear an audible click.
    • The screws will not separate from the bottom cover when loose.
  3. Lenovo ThinkPad Yoga 260 Repair RAM Replacement: passo 3, immagine 1 di 2 Lenovo ThinkPad Yoga 260 Repair RAM Replacement: passo 3, immagine 2 di 2
    • The bottom cover is attached via several plastic clips located around the edges of the bottom cover.
    • Using a plastic opening tool, gently pry the bottom cover from the laptop.
    • Work the plastic opening tool around the edges of the bottom cover undoing all of the plastic clips, as shown in the picture.
  4. Lenovo ThinkPad Yoga 260 Repair RAM Replacement: passo 4, immagine 1 di 2 Lenovo ThinkPad Yoga 260 Repair RAM Replacement: passo 4, immagine 2 di 2
    • Place your fingers around the edges of the cover and remove it.
  5. Lenovo ThinkPad Yoga 260 Repair RAM Replacement, RAM: passo 5, immagine 1 di 2 Lenovo ThinkPad Yoga 260 Repair RAM Replacement, RAM: passo 5, immagine 2 di 2
    • Using both thumbs, pinch the RAM's mounting clips outward.
    • The RAM module will spring up on its own.
  6. Lenovo ThinkPad Yoga 260 Repair RAM Replacement: passo 6, immagine 1 di 1
    • Gently remove it from its mounting.
Conclusione
Altre 4 persone hanno completato questa guida.
USF Tampa, Team S2-G3, Eyestone Spring 2018 Membro di USF Tampa, Team S2-G3, Eyestone Spring 2018
USFT-EYESTONE-S18S2G3
4 Membri
5 Guide realizzate
3 Commenti
how many ram slot in lenovo yoga 260
The Great - Replica
Just 1 slot :-(
Erik Chorn -
Hello,
I need help.
My yoga 260 does not have any slot and I already bought a 16gb ddr4
tovitottovi963 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 3,059
