Salta al contenuto principale
Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement
Cosa ti serve
  1. Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement, Back Cover: passo 1, immagine 1 di 1
    • Ensure the device is off and unplugged.
    • Remove the stylus from its port and set aside.
  2. Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement: passo 2, immagine 1 di 2 Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement: passo 2, immagine 2 di 2
    • Using a Phillips #1 screwdriver, gently unscrew the eight 1.3 mm Phillips #1 screws until you hear an audible click.
    • The screws will not separate from the bottom cover when loose.
  3. Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement: passo 3, immagine 1 di 2 Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement: passo 3, immagine 2 di 2
    • The bottom cover is attached via several plastic clips located around the edges of the bottom cover.
    • Using a plastic opening tool, gently pry the bottom cover from the laptop.
    • Work the plastic opening tool around the edges of the bottom cover undoing all of the plastic clips, as shown in the picture.
  4. Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement: passo 4, immagine 1 di 2 Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement: passo 4, immagine 2 di 2
    • Place your fingers around the edges of the cover and remove it.
  5. Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement, Heat Sink: passo 5, immagine 1 di 2 Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement, Heat Sink: passo 5, immagine 2 di 2
    • Heatsink should be cool to the touch.
    • Using your index fingers, gently remove the fan’s power connection.
  6. Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement: passo 6, immagine 1 di 2 Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement: passo 6, immagine 2 di 2
    • Using a Phillips #1 screwdriver, remove the four 1.3 mm Phillips #1 screws and set them aside.
    • The screws will not separate from the mounting when loose.
  7. Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement: passo 7, immagine 1 di 1
    • Using your index finger and thumb, gently pry the cooler from its mountings and remove the assembly.
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team S2-G3, Eyestone Spring 2018 Membro di USF Tampa, Team S2-G3, Eyestone Spring 2018
USFT-EYESTONE-S18S2G3
4 Membri
5 Guide realizzate
Un commento
Good guide, thank you. Clear and concise with very easy to follow pictures and instruction. As usual, iFixit to the rescue :-)
Mark Taylor (wodin69) - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,197
