Introduzione
The heat sink regulates the temperature of the laptop. If you have a faulty heat sink, this guide will show you how to replace it.
Parti
Nessuna parte richiesta.
  1. Ensure the device is off and unplugged.
    • Ensure the device is off and unplugged.
    • Remove the stylus from its port and set aside.
  2. Using a Phillips screwdriver, unscrew the 8 PH1 Phillips fasteners until you hear an audible click. The screws will not separate from the bottom cover when loose.
    • Using a Phillips screwdriver, unscrew the 8 PH1 Phillips fasteners until you hear an audible click.
    • The screws will not separate from the bottom cover when loose.
  3. The bottom cover is attached via several plastic clips located around the edges of the bottom cover. Using a plastic opening tool, gently pry the bottom cover from the laptop.
    • The bottom cover is attached via several plastic clips located around the edges of the bottom cover.
    • Using a plastic opening tool, gently pry the bottom cover from the laptop.
    • Work the plastic opening tool around the edges of the bottom cover undoing all of the plastic clips, as shown in the picture.
  4. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  5. Place your fingers around the edges of the cover and remove it. Place your fingers around the edges of the cover and remove it.
    • Place your fingers around the edges of the cover and remove it.
  6. Heatsink should be cool to the touch. Using your index fingers, gently remove the fan’s power connection.
    • Heatsink should be cool to the touch.
    • Using your index fingers, gently remove the fan’s power connection.
  7. Using a Phillips screwdriver, remove the 4 PH1 Phillips fasteners and set them aside. The screws will not separate from the mounting when loose.
    • Using a Phillips screwdriver, remove the 4 PH1 Phillips fasteners and set them aside.
    • The screws will not separate from the mounting when loose.
  8. Using your index finger and thumb, gently pry the cooler from its mountings and remove the assembly.
    • Using your index finger and thumb, gently pry the cooler from its mountings and remove the assembly.
Conclusione
Daniel Fernandez
Membro da: 14/02/2018
729 Reputazione
5 Guide realizzate
USF Tampa, Team S2-G3, Eyestone Spring 2018 Membro di USF Tampa, Team S2-G3, Eyestone Spring 2018
USFT-EYESTONE-S18S2G3
4 Membri
5 Guide realizzate
Good guide, thank you. Clear and concise with very easy to follow pictures and instruction. As usual, iFixit to the rescue :-)
Mark Taylor (wodin69) - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 18
Tutti i Tempi: 187
