Salta al contenuto principale
Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement
Cosa ti serve
  1. Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Unplug and completely shut down your computer beforehand to reduce the risk of electric shock.
    • Flip the laptop over so you can see the bottom panel.
    • Unscrew the circled screws to detach the keyboard.
  2. Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement: passo 2, immagine 1 di 3 Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement: passo 2, immagine 2 di 3 Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement: passo 2, immagine 3 di 3
    • Flip the laptop back over and open it normally.
    • Use a plastic opening tool to lift up the keyboard along the bottom edge until it is detached.
  3. Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement: passo 3, immagine 1 di 2 Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement: passo 3, immagine 2 di 2
    • Using a finger, push the top of the keyboard out of its holder to completely detach it.
    • Move the keyboard out of the way by rotating the far side of the keyboard towards you.
  4. Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement: passo 4, immagine 1 di 2 Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement: passo 4, immagine 2 di 2
    • Be gentle! These connectors are very small and can easily break off.
    • Lay the keyboard on its front.
    • Disconnect the 3 cables by pulling on the attached tabs.
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team S14-G2, Banghart Spring 2017 Membro di Cal Poly, Team S14-G2, Banghart Spring 2017
CPSU-BANGHART-S17S14G2
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 21
Tutti i Tempi: 5,564
