Salta al contenuto principale
Lenovo ThinkPad X280 CMOS Battery Replacement
Cosa ti serve
  1. Lenovo ThinkPad X280 CMOS Battery Replacement, Back Panel: passo 1, immagine 1 di 1
    • To begin, ensure that the device is completely powered off and not connected to an energy supply.
    • Close the device and flip it over to expose the back panel.
  2. Lenovo ThinkPad X280 CMOS Battery Replacement: passo 2, immagine 1 di 2 Lenovo ThinkPad X280 CMOS Battery Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #1 screwdriver to unscrew the five captive screws on the back panel until a small pop is heard.
    • These are captive screws and do not come out completely.
  3. Lenovo ThinkPad X280 CMOS Battery Replacement: passo 3, immagine 1 di 2 Lenovo ThinkPad X280 CMOS Battery Replacement: passo 3, immagine 2 di 2
    • Gently wedge an opening tool or spudger under the back panel, and loosen the clips around the perimeter until the back panel comes off.
    • Remove the back cover.
  4. Lenovo ThinkPad X280 CMOS Battery Replacement, Battery: passo 4, immagine 1 di 3 Lenovo ThinkPad X280 CMOS Battery Replacement, Battery: passo 4, immagine 2 di 3 Lenovo ThinkPad X280 CMOS Battery Replacement, Battery: passo 4, immagine 3 di 3
    • Using the Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery down.
    • Remove the battery.
  5. Lenovo ThinkPad X280 CMOS Battery Replacement, CMOS Battery: passo 5, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Use tweezers to gently unplug the CMOS Battery from the port on the right side.
  6. Lenovo ThinkPad X280 CMOS Battery Replacement: passo 6, immagine 1 di 1
    • Work the wire out from its holding brackets and is now free to be removed.
Conclusione
Altre 3 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 34
Ultimi 30 Giorni: 202
Tutti i Tempi: 4,100
