Salta al contenuto principale
Lenovo ThinkPad X260 Back Cover Replacement
Cosa ti serve
  1. Lenovo ThinkPad X260 Back Cover Replacement, External Battery: passo 1, immagine 1 di 2 Lenovo ThinkPad X260 Back Cover Replacement, External Battery: passo 1, immagine 2 di 2
    • Make sure that the device is unplugged and turned off.
    • Flip the laptop from the front to the back.
  2. Lenovo ThinkPad X260 Back Cover Replacement: passo 2, immagine 1 di 3 Lenovo ThinkPad X260 Back Cover Replacement: passo 2, immagine 2 di 3 Lenovo ThinkPad X260 Back Cover Replacement: passo 2, immagine 3 di 3
    • Start by pinching the switches on either side of the battery outwards.
    • At the same time push the external battery, located in the back, upwards.
    • Remove the external battery from the laptop.
  3. Lenovo ThinkPad X260 Back Cover Replacement, Back Cover: passo 3, immagine 1 di 3 Lenovo ThinkPad X260 Back Cover Replacement, Back Cover: passo 3, immagine 2 di 3 Lenovo ThinkPad X260 Back Cover Replacement, Back Cover: passo 3, immagine 3 di 3
    • Loosen the eight 4.2 mm screws holding the back cover on using a Phillips #1 screwdriver.
    • These screws should be held in place by a small plastic washer which secures them to the cover and should not be loosened. This is illustrated in the third image.
  4. Lenovo ThinkPad X260 Back Cover Replacement: passo 4, immagine 1 di 3 Lenovo ThinkPad X260 Back Cover Replacement: passo 4, immagine 2 di 3 Lenovo ThinkPad X260 Back Cover Replacement: passo 4, immagine 3 di 3
    • Gently pull the cover off and set aside.
    • An iFixit opening tool may make it easier to gently remove the cover.
Conclusione
Alexander Webb
Membro da: 12/06/21
193 Reputazione
2 Guide realizzate
IUPUI, Team 1-3, Harley Summer 2023 Membro di IUPUI, Team 1-3, Harley Summer 2023
IUPUI-HARLEY-SU23S1G3
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 69
Tutti i Tempi: 322
