Salta al contenuto principale
Lenovo ThinkPad X140e Speakers Replacement
Cosa ti serve
  1. Lenovo ThinkPad X140e Speakers Replacement, Keyboard: passo 1, immagine 1 di 1
    • Set the laptop facing you with the screen open.
  2. Lenovo ThinkPad X140e Speakers Replacement: passo 2, immagine 1 di 2 Lenovo ThinkPad X140e Speakers Replacement: passo 2, immagine 2 di 2
    • Using a small plastic opening tool, pry off the keyboard starting at a point closest to you and working around the perimeter.
  3. Lenovo ThinkPad X140e Speakers Replacement: passo 3, immagine 1 di 3 Lenovo ThinkPad X140e Speakers Replacement: passo 3, immagine 2 di 3 Lenovo ThinkPad X140e Speakers Replacement: passo 3, immagine 3 di 3
    • Flip up the ZIF connector that is holding the small ribbon cable in place.
    • Proceed to pull out the small ribbon cable
  4. Lenovo ThinkPad X140e Speakers Replacement: passo 4, immagine 1 di 3 Lenovo ThinkPad X140e Speakers Replacement: passo 4, immagine 2 di 3 Lenovo ThinkPad X140e Speakers Replacement: passo 4, immagine 3 di 3
    • Flip up the ZIF connector that is holding the larger ribbon cable in place.
    • Proceed to pull out the large ribbon cable.
  5. Lenovo ThinkPad X140e Speakers Replacement, Speakers: passo 5, immagine 1 di 1
    • Flip the laptop upside down such that the battery would be facing away from you.
    • Remove the two 3mm Phillips #0 screws in the back located on either side of the battery.
    • Back panel and battery removal are not necessary for completion of this guide.
  6. Lenovo ThinkPad X140e Speakers Replacement: passo 6, immagine 1 di 2 Lenovo ThinkPad X140e Speakers Replacement: passo 6, immagine 2 di 2
    • Flip the laptop right-side up and open it so that the screen is facing you.
    • Pry off the front panel using a small plastic opening tool starting at a corner and working around the perimeter
  7. Lenovo ThinkPad X140e Speakers Replacement: passo 7, immagine 1 di 2 Lenovo ThinkPad X140e Speakers Replacement: passo 7, immagine 2 di 2
    • The speakers are located on the bottom of the laptop, where the mouse pad is located.
    • Remove the four 4.5 mm Phillips #0 screws on either side of both speakers.
  8. Lenovo ThinkPad X140e Speakers Replacement: passo 8, immagine 1 di 3 Lenovo ThinkPad X140e Speakers Replacement: passo 8, immagine 2 di 3 Lenovo ThinkPad X140e Speakers Replacement: passo 8, immagine 3 di 3
    • Remove the cable that is attached from the speakers to the board.
    • Unhook the black wire that connects the speaker on the left to the speaker on the right.
    • After unhooking the wire, simply pull the speakers out of the laptop.
Conclusione
Cal Poly, Team 20-5, Livingston Fall 2016 Membro di Cal Poly, Team 20-5, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G5
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 31
Tutti i Tempi: 2,877
