Salta al contenuto principale
Lenovo ThinkPad X140e Keyboard Replacement
Cosa ti serve
  1. Lenovo ThinkPad X140e Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Set the laptop facing you with the screen open.
  2. Lenovo ThinkPad X140e Keyboard Replacement: passo 2, immagine 1 di 2 Lenovo ThinkPad X140e Keyboard Replacement: passo 2, immagine 2 di 2
    • Using a small plastic opening tool, pry off the keyboard starting at a point closest to you and working around the perimeter.
  3. Lenovo ThinkPad X140e Keyboard Replacement: passo 3, immagine 1 di 3 Lenovo ThinkPad X140e Keyboard Replacement: passo 3, immagine 2 di 3 Lenovo ThinkPad X140e Keyboard Replacement: passo 3, immagine 3 di 3
    • Flip up the ZIF connector that is holding the small ribbon cable in place.
    • Proceed to pull out the small ribbon cable
  4. Lenovo ThinkPad X140e Keyboard Replacement: passo 4, immagine 1 di 3 Lenovo ThinkPad X140e Keyboard Replacement: passo 4, immagine 2 di 3 Lenovo ThinkPad X140e Keyboard Replacement: passo 4, immagine 3 di 3
    • Flip up the ZIF connector that is holding the larger ribbon cable in place.
    • Proceed to pull out the large ribbon cable.
Conclusione
kevin hull
Membro da: 10/05/16
213 Reputazione
2 Guide realizzate
Cal Poly, Team 20-5, Livingston Fall 2016 Membro di Cal Poly, Team 20-5, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G5
4 Membri
5 Guide realizzate
4 Commenti
how can I buy a keyboard for my lenovo thinkpad x140e laptop?
Bryan - Replica
The keyboard for the X140e is the same as the one for the X130e and the X131e and the X121e.
It is FRU 04y0379
Buy the keyboard on eBay.
atexit8 -
Just as a note, there are two screws that keep that keyboard held in place. You need to remove the back panel and take out those two screws, otherwise you’re going to have a tough time. Also, you really don’t need the pry tool, once those screws are out, the keyboard slides off. The rest of the process is spot on.
Jeffrey Chocklette - Replica
Don’t forget the screws, otherwise you will never get the keyboard off or worse damage it during removal
celticxxtwin - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,716
