Salta al contenuto principale
Lenovo ThinkPad X140e Battery Replacement
Cosa ti serve
  1. Lenovo ThinkPad X140e Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Turn off your laptop and unplug the charging cable.
    • Failure to remove the charging cable may cause electric shock.
    • Flip the laptop upside down.
    • Rotate the laptop so that the battery is facing away from you.
  2. Lenovo ThinkPad X140e Battery Replacement: passo 2, immagine 1 di 1
    • Push the first switch on the left to the right until you hear a click. This means the battery is unlocked and can be removed.
  3. Lenovo ThinkPad X140e Battery Replacement: passo 3, immagine 1 di 2 Lenovo ThinkPad X140e Battery Replacement: passo 3, immagine 2 di 2
    • Push the second switch on the right to the right, hold it there with your right hand and continue to the next step.
    • While holding the right switch open, take your free hand and pull the battery out.
Conclusione
Cal Poly, Team 20-5, Livingston Fall 2016 Membro di Cal Poly, Team 20-5, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G5
4 Membri
5 Guide realizzate
Un commento
I did this, but the computer says that the battery is not genuine, and then refuses to charge the battery. What do I do?
Justine Akehurst - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 990
