Salta al contenuto principale
Introduzione
This guide is for removing the ThinkPad X100e's LCD display and replacing it with a new one.
    • Use a Spudger tool to remove the screw covers on each side of the screen.
    • Be sure not to lose screw covers.
  1. Using a magnetic screwdriver fit with a PH0 Bit, unscrew the two screws and carefully set the aside.
    • Using a magnetic screwdriver fit with a PH0 Bit, unscrew the two screws and carefully set the aside.
  2. Pry open the bezel carefully with the spudger tool.
    • Pry open the bezel carefully with the spudger tool.
    • You will want to do this until the frame is completely off.
  3. Remove all exposed screws and carefully set them aside. There should be 6 visible screws.
    • Remove all exposed screws and carefully set them aside. There should be 6 visible screws.
    • Be sure to set the screws aside on the magnetic mat.
  4. Batterie per PC portatili
    Una soluzione semplice per un grande aumento di potenza.
    Acquista ora
    Acquista ora
  5. Lift the screen up carefully, and remove the screws on both sides of the panel. There should be 4 screws.
    • Lift the screen up carefully, and remove the screws on both sides of the panel. There should be 4 screws.
    • The other two screws are located in the exact place on the other side.
    • Don't forget to place the screws on the magnetic mat, separate from other screws.
  6. Remove the connector located at the very top of the screen beside the webcam. To remove the connector, simply pull the connector out.
    • Remove the connector located at the very top of the screen beside the webcam.
    • To remove the connector, simply pull the connector out.
  7. Fold the panel over until a strip of black tape is visible.
    • Fold the panel over until a strip of black tape is visible.
    • Peel the tape down until you get to the base.
  8. Peel the piece of transparent tape back. At this point there should be some exposed wires underneath the tape.
    • Peel the piece of transparent tape back.
    • At this point there should be some exposed wires underneath the tape.
  9. Remove the connector carefully with the spudger tool.
    • Remove the connector carefully with the spudger tool.
  10. Remove the black tape fully.
    • Remove the black tape fully.
    • Now your device is ready for a new panel.
Conclusione
What can be used as a replacement screen, as it's listed not for sale?
Keith Bowe - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 262
