Salta al contenuto principale
Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement
Cosa ti serve
  1. Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement, Back Cover: passo 1, immagine 1 di 1
    • Ensure the laptop is powered off and the charging cable is disconnected before opening the back cover.
    • Flip over the laptop to access the back cover.
  2. Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement: passo 2, immagine 1 di 2 Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #0 screwdriver to remove the eight 8 mm screws.
  3. Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement: passo 3, immagine 1 di 1
    • Remove the back cover.
    • A popping sound may occur when the back cover is removed.
  4. Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement, Speakers: passo 4, immagine 1 di 2 Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement, Speakers: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    $3.99
    Compra
    • Follow the ribbon cable that runs from the left speaker to the motherboard.
    • Pull the black connector up and release the cable wire by hand.
    • If needed, pull this connector up using the Pro/ESD/angled tweezers.
  5. Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement: passo 5, immagine 1 di 2 Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement: passo 5, immagine 2 di 2
    • Remove two 6 mm Phillips #0 screws from each speaker.
  6. Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement: passo 6, immagine 1 di 2 Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement: passo 6, immagine 2 di 2
    • Use your fingers to remove the speakers from the device.
  7. Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement, Battery: passo 7, immagine 1 di 1
    • Use a spudger to pop the ribbon cable that runs from the upper-middle portion of the battery to the motherboard out of the motherboard.
    • Do not use a metal spudger as indicated in the photos. The metal spudger should only be used for serious prying power. If it's used on the internal components of a device, it may puncture or damage the components in your device.
  8. Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement: passo 8, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove one 6 mm screw from the bottom-middle portion of the battery.
  9. Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement: passo 9, immagine 1 di 1
    • Remove the battery.
  10. Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement, Trackpad: passo 10, immagine 1 di 2 Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement, Trackpad: passo 10, immagine 2 di 2
    • Using a Phillips #0 screwdriver, remove four 3 mm screws.
  11. Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement: passo 11, immagine 1 di 1
    • Lift up the laptop and remove the trackpad from the device.
    • When you lift up the bottom panel, the trackpad should fall from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 14
Tutti i Tempi: 505
