Salta al contenuto principale
Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement
Cosa ti serve
  1. Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement, Back Cover: passo 1, immagine 1 di 1
    • Ensure the laptop is powered off and the charging cable is disconnected before opening the back cover.
    • Flip over the laptop to access the back cover.
  2. Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement: passo 2, immagine 1 di 2 Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #0 screwdriver to remove the eight 8 mm screws.
  3. Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement: passo 3, immagine 1 di 1
    • Remove the back cover.
    • A popping sound may occur when the back cover is removed.
  4. Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement, SSD: passo 4, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove one 6 mm screw.
  5. Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement: passo 5, immagine 1 di 2 Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement: passo 5, immagine 2 di 2
    • Slide the SSD out of the shiny covering.
    • Remove the SSD.
Conclusione
Altre 9 persone hanno completato questa guida.
Cal Poly, Team S22-G3, Regan Winter 2020 Membro di Cal Poly, Team S22-G3, Regan Winter 2020
CPSU-REGAN-W20S22G3
5 Membri
7 Guide realizzate
Un commento
What kind of SSD is this compatible with? There are several different connector standards…
Shai Revzen - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 97
Tutti i Tempi: 8,120
