Salta al contenuto principale
Lenovo ThinkPad X1 Extreme SSD Replacement
Cosa ti serve
  1. Lenovo ThinkPad X1 Extreme SSD Replacement, Back Cover: passo 1, immagine 1 di 3 Lenovo ThinkPad X1 Extreme SSD Replacement, Back Cover: passo 1, immagine 2 di 3 Lenovo ThinkPad X1 Extreme SSD Replacement, Back Cover: passo 1, immagine 3 di 3
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Extreme SSD Replacement, SSD: passo 2, immagine 1 di 2 Lenovo ThinkPad X1 Extreme SSD Replacement, SSD: passo 2, immagine 2 di 2
    • Using the Phillips #00 screwdriver, remove the single screw securing the SSD to the motherboard.
  3. Lenovo ThinkPad X1 Extreme SSD Replacement: passo 3, immagine 1 di 2 Lenovo ThinkPad X1 Extreme SSD Replacement: passo 3, immagine 2 di 2
    • Using the opening tool, pop out the SSD card and remove it from the device.
Conclusione
1Commento della guida
Anyhow this laptop support gen 4 nvme or higher?
jordan chong - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 59
Tutti i Tempi: 2,715
