Salta al contenuto principale
Lenovo ThinkPad X1 Extreme RAM Replacement
Cosa ti serve
  1. Lenovo ThinkPad X1 Extreme RAM Replacement, Back Cover: passo 1, immagine 1 di 3 Lenovo ThinkPad X1 Extreme RAM Replacement, Back Cover: passo 1, immagine 2 di 3 Lenovo ThinkPad X1 Extreme RAM Replacement, Back Cover: passo 1, immagine 3 di 3
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Extreme RAM Replacement, RAM: passo 2, immagine 1 di 1
    • Use an opening tool to unlatch the silver gate on the side of the RAM by pushing it away from the component.
    • Repeat the same process to the other side of the RAM.
  3. Lenovo ThinkPad X1 Extreme RAM Replacement: passo 3, immagine 1 di 1
    • Gently grab the RAM and slide it up and away from the connector at the bottom of the component.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,005
