Salta al contenuto principale
Introduzione
With so many components playing a role to make a computer function, it’s important for the components to be able to communicate with each other. The motherboard acts as the central hub of communication for all components in a device. If you find that your computer is acting slow, struggling to load, or displays the blue screen of death (BSoD), your motherboard may be faulty. Follow these instructions to replace the motherboard in your device.
  1. Be sure to power off and unplug your device before you begin your repair. Orient the laptop so that it is bottom up, and the track pad is closest to you.
    • Be sure to power off and unplug your device before you begin your repair.
    • Orient the laptop so that it is bottom up, and the track pad is closest to you.
    • Unscrew the seven cover screws with a Phillips #00 head screwdriver. These screws will loosen, but will stay attached to the cover.
    • Slide the blue opening pick along the side of the laptop and pry off the one clip on each side.
    • The cover should easily come off.
  2. Use a Phillips #00 head screwdriver to remove the four, 4mm screws above the battery.
    • Use a Phillips #00 head screwdriver to remove the four, 4mm screws above the battery.
  3. Lift the speaker modules on either side of the battery out of its pegs, and unwind the cable from the front of the battery.
    • Lift the speaker modules on either side of the battery out of its pegs, and unwind the cable from the front of the battery.
    • Set the speaker modules out of the way.
  4. Using tweezers, peel the plastic cover off the connector. Use a spudger or your fingernail to pry up the battery straight up from the motherboard. Use a spudger or your fingernail to pry up the battery straight up from the motherboard.
    • Using tweezers, peel the plastic cover off the connector.
    • Use a spudger or your fingernail to pry up the battery straight up from the motherboard.
  5. Lift the battery out of the frame and remove it from the device.
    • Lift the battery out of the frame and remove it from the device.
  6. Unscrew the 3mm screw holding down  the wireless adapter using a Phillips #00 screwdriver. Slide the adapter out of its connector. Detach the black and gray cables and separate them from the frame of the fan by gently pulling upwards.
    • Unscrew the 3mm screw holding down the wireless adapter using a Phillips #00 screwdriver.
    • Slide the adapter out of its connector.
    • Detach the black and gray cables and separate them from the frame of the fan by gently pulling upwards.
  7. Unlatch and remove the cable connecting to the frame of the fan by flipping the thin black tab up. Separate the cable from the frame of the fan.
    • Unlatch and remove the cable connecting to the frame of the fan by flipping the thin black tab up.
    • Separate the cable from the frame of the fan.
  8. Loosen the five screws connecting the fan to the motherboard using a Philips #00 head screwdriver. These screws will not come out and will stay connected to the fan.
    • Loosen the five screws connecting the fan to the motherboard using a Philips #00 head screwdriver.
    • These screws will not come out and will stay connected to the fan.
  9. Gently disconnect the two cables located on right and left side of the fan. To identify these, they are labeled "FANR1" and FANL2" on the motherboard. Lift the fan up and out and remove it from the device.
    • Gently disconnect the two cables located on right and left side of the fan.
    • To identify these, they are labeled "FANR1" and FANL2" on the motherboard.
    • Lift the fan up and out and remove it from the device.
  10. Using the Phillips #00 head screwdriver, remove the five 4mm screws below the charging port. holding down the motherboard. Remove the two 3mm left most screws. Remove the two 5mm screws that are holding down a silver plate on the charging port in the top right.
    • Using the Phillips #00 head screwdriver, remove the five 4mm screws below the charging port. holding down the motherboard.
    • Remove the two 3mm left most screws.
    • Remove the two 5mm screws that are holding down a silver plate on the charging port in the top right.
    • Remove the silver plate on top of the charging port. This is needed so that the mother board may be removed.
  11. Disconnect all the ribbon wires from the motherboard. All ribbon wires can be disconnected by flipping up the thin black tab at their connection points, and pulling the ribbon out. All ribbon wires can be disconnected by flipping up the thin black tab at their connection points, and pulling the ribbon out.
    • Disconnect all the ribbon wires from the motherboard.
    • All ribbon wires can be disconnected by flipping up the thin black tab at their connection points, and pulling the ribbon out.
  12. Disconnect the black attachment at the top right corner of the motherboard. Insert the SIM eject bit into the small hole on the top and apply a small amount of pressure to release the clip. While maintaining pressure, gently pull on the wire that is connected to it to remove it.
    • Disconnect the black attachment at the top right corner of the motherboard.
    • Insert the SIM eject bit into the small hole on the top and apply a small amount of pressure to release the clip.
    • While maintaining pressure, gently pull on the wire that is connected to it to remove it.
  13. Gently lift the motherboard out of the computer.
    • Gently lift the motherboard out of the computer.
Conclusione
Brant Baugher
Membro da: 10/02/2020
115 Reputazione
1 Guida realizzata
Cal Poly, Team S7-G3, Regan Winter 2020 Membro di Cal Poly, Team S7-G3, Regan Winter 2020
CPSU-REGAN-W20S7G3
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 58
Tutti i Tempi: 989
