Salta al contenuto principale
Lenovo ThinkPad X1 Extreme Charging Port Replacement
Cosa ti serve
  1. Lenovo ThinkPad X1 Extreme Charging Port Replacement, Back Cover: passo 1, immagine 1 di 3 Lenovo ThinkPad X1 Extreme Charging Port Replacement, Back Cover: passo 1, immagine 2 di 3 Lenovo ThinkPad X1 Extreme Charging Port Replacement, Back Cover: passo 1, immagine 3 di 3
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Extreme Charging Port Replacement, Fan: passo 2, immagine 1 di 3 Lenovo ThinkPad X1 Extreme Charging Port Replacement, Fan: passo 2, immagine 2 di 3 Lenovo ThinkPad X1 Extreme Charging Port Replacement, Fan: passo 2, immagine 3 di 3
    • Unscrew the 3mm screw holding down the wireless adapter using a Phillips #00 screwdriver.
    • Slide the adapter out of its connector.
    • Detach the black and gray cables and separate them from the frame of the fan by gently pulling upwards.
  3. Lenovo ThinkPad X1 Extreme Charging Port Replacement: passo 3, immagine 1 di 2 Lenovo ThinkPad X1 Extreme Charging Port Replacement: passo 3, immagine 2 di 2
    • Unlatch and remove the cable connecting to the frame of the fan by flipping the thin black tab up.
    • Separate the cable from the frame of the fan.
  4. Lenovo ThinkPad X1 Extreme Charging Port Replacement: passo 4, immagine 1 di 2 Lenovo ThinkPad X1 Extreme Charging Port Replacement: passo 4, immagine 2 di 2
    • Loosen the five screws connecting the fan to the motherboard using a Philips #00 head screwdriver.
    • These screws will not come out and will stay connected to the fan.
  5. Lenovo ThinkPad X1 Extreme Charging Port Replacement: passo 5, immagine 1 di 3 Lenovo ThinkPad X1 Extreme Charging Port Replacement: passo 5, immagine 2 di 3 Lenovo ThinkPad X1 Extreme Charging Port Replacement: passo 5, immagine 3 di 3
    • Gently disconnect the two cables located on right and left side of the fan.
    • To identify these, they are labeled "FANR1" and FANL2" on the motherboard.
    • Lift the fan up and out and remove it from the device.
  6. Lenovo ThinkPad X1 Extreme Charging Port Replacement, Charging Port: passo 6, immagine 1 di 1
    • Using the Phillips #00 screwdriver, remove the two screws on the cover of the charging port.
  7. Lenovo ThinkPad X1 Extreme Charging Port Replacement: passo 7, immagine 1 di 2 Lenovo ThinkPad X1 Extreme Charging Port Replacement: passo 7, immagine 2 di 2
    • Disconnect the charging port cable from the motherboard.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 57
Tutti i Tempi: 1,883
