Introduzione
This guide will show you how to replace the keyboard in your Lenovo ThinkPad X1 Carbon 7th Generation laptop. Reasons for failure of your keyboard may include the keyboard becoming unresponsive, dust or particles stuck that must be removed to allow functionality of the keyboard, visible damage to the keyboard, or loosened keys. If you are experiencing any of these issues, a keyboard replacement should restore your laptop to working condition.
Cosa ti serve
Use a Phillips #1 screwdriver to loosen the five captive screws securing the back cover.
Insert an opening pick at a 45Ëš angle between the back cover and frame near the rear middle screw.
Pry up on the pick to release the clips securing the back cover to the frame.
Use a Phillips #0 screwdriver to remove the six 4.9Â mm-long screws securing the battery.
Remove the connectors with bar latches by lifting up on the small bar behind the port and pulling the circuit ribbon away from the port.
Using a Phillips #00 screwdriver, remove sixty-six 0.5 mm screws from the keyboard.
Altre 6 persone hanno completato questa guida.
2 Commenti
I did this and the new keyboard only works for 1 minutes be for stopping
