Salta al contenuto principale
Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement Replacement
Cosa ti serve
  1. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement, Back Cover: passo 1, immagine 1 di 1
    • Turn the laptop on to its back.
  2. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: passo 2, immagine 1 di 1
    • Use the Phillips #1 screwdriver to remove five 1.2 mm screws from the back cover of the laptop.
  3. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: passo 3, immagine 1 di 1
    • Remove the back cover using the opening tool, leaving the laptop back exposed.
    • Use the opening tool to pry the edge and work your way around the perimeter.
    • Careful to undo the clips before removing the back cover.
  4. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement, Battery: passo 4, immagine 1 di 2 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement, Battery: passo 4, immagine 2 di 2
    • Use the Phillips #1 screwdriver to remove the four 1.2 mm screws that secure the battery.
  5. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: passo 5, immagine 1 di 3 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: passo 5, immagine 2 di 3 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: passo 5, immagine 3 di 3
    • Remove the battery using your hand or a prying tool.
  6. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement, Speakers: passo 6, immagine 1 di 2 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement, Speakers: passo 6, immagine 2 di 2
    • Use the Phillips #1 screwdriver to remove the two 1.2 mm screws.
  7. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: passo 7, immagine 1 di 3 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: passo 7, immagine 2 di 3 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: passo 7, immagine 3 di 3
    • Unplug the speaker cable from the board.
  8. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: passo 8, immagine 1 di 3 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: passo 8, immagine 2 di 3 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: passo 8, immagine 3 di 3
    • Lift up the marked latch and remove the cable.
    • Remove the speaker.
Conclusione
You will have the speaker replaced and fully working. To reassemble your device, follow these instructions in reverse order.
Gateway, Team 1-3, Saknee Fall 2021 Membro di Gateway, Team 1-3, Saknee Fall 2021
GCC-SAKNEE-F21S1G3
4 Membri
15 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 42
Tutti i Tempi: 884
