Salta al contenuto principale
Lenovo ThinkPad X1 Carbon 5th Gen Back Cover Removal
Cosa ti serve
  1. Lenovo ThinkPad X1 Carbon 5th Gen Back Cover Removal, Back Cover: passo 1, immagine 1 di 1
    • Turn the laptop on to its back.
  2. Lenovo ThinkPad X1 Carbon 5th Gen Back Cover Removal: passo 2, immagine 1 di 1
    • Use the Phillips #1 screwdriver to remove five 1.2 mm screws from the back cover of the laptop.
  3. Lenovo ThinkPad X1 Carbon 5th Gen Back Cover Removal: passo 3, immagine 1 di 1
    • Remove the back cover using the opening tool, leaving the laptop back exposed.
    • Use the opening tool to pry the edge and work your way around the perimeter.
    • Careful to undo the clips before removing the back cover.
Conclusione
If you follow these steps the back of the laptop will be exposed so you can work on other components of the laptop.
To put it back together follow these steps in reverse
Gateway, Team 1-3, Saknee Fall 2021 Membro di Gateway, Team 1-3, Saknee Fall 2021
GCC-SAKNEE-F21S1G3
4 Membri
15 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 32
Ultimi 30 Giorni: 162
Tutti i Tempi: 2,907
