Salta al contenuto principale
Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement
Cosa ti serve
  1. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement, Back Cover: passo 1, immagine 1 di 1
    • Using a Phillips #0 screwdriver, remove the seven 7mm screws holding the back cover onto your computer.
  2. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: passo 2, immagine 1 di 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: passo 2, immagine 2 di 2
    • Use a plastic opening tool or your fingers to pry off the cover.
  3. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement, Battery: passo 3, immagine 1 di 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement, Battery: passo 3, immagine 2 di 2
    • Using your fingers, disconnect the battery from the motherboard.
  4. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: passo 4, immagine 1 di 1
    • Using a Phillips #0 screwdriver, unscrew the five 4.3mm screws attaching the battery to the computer.
  5. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: passo 5, immagine 1 di 1
    • Remove the battery by pulling it directly towards you.
  6. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement, Touchpad: passo 6, immagine 1 di 1
    • Remove the black ribbon cable connected to the touchpad.
  7. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: passo 7, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove the four 1.9 mm screws holding in the touchpad.
  8. Lenovo ThinkPad X1 Carbon (2nd Gen) Touchpad Replacement: passo 8, immagine 1 di 1
    • Remove the touchpad by opening the computer and letting it drop onto your hand.
Conclusione
Eevee Murdock
Membro da: 01/23/20
1.086 Reputazione
6 Guide realizzate
Cal Poly, Team S18-G4, White Winter 2020 Membro di Cal Poly, Team S18-G4, White Winter 2020
CPSU-WHITE-W20S18G4
4 Membri
9 Guide realizzate
2 Commenti
Even the weirder of their models is still amazingly engineered, this was so easy to do and finding parts - not only of the same model but compatible newer parts - was an absolute breeze! Was able to upgrade my laptop during my work lunchtime, and still have time to actually eat lunch!
Casey - Replica
Just to confirm - Thinkpad X1 Carbon Generation 3 touchpads are compatible with this model, and make for an amazing upgrade.
Casey - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,763
