Introduzione
If the speakers on your Lenovo ThinkPad X1 Carbon (2nd Gen) make popping sounds, distorted sounds, or no sounds, use this guide to replace your speakers.
The speakers play the audio from your computer.
Before using this guide, check if your audio has been disabled or you need to update the audio drivers. This will check if your speaker problems are from faulty software or hardware.
Before you begin, make sure your computer is off.
Cosa ti serve
Using a Phillips #0 screwdriver, remove the seven 7mm screws holding the back cover onto your computer.
Use a Phillips #0 screwdriver to remove the four 4.6mm screws holding the speakers.
