Salta al contenuto principale
Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement
Cosa ti serve
  1. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement, Back Cover: passo 1, immagine 1 di 1
    • Using a Phillips #0 screwdriver, remove the seven 7mm screws holding the back cover onto your computer.
  2. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: passo 2, immagine 1 di 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: passo 2, immagine 2 di 2
    • Use a plastic opening tool or your fingers to pry off the cover.
  3. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement, Battery: passo 3, immagine 1 di 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement, Battery: passo 3, immagine 2 di 2
    • Using your fingers, disconnect the battery from the motherboard.
  4. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: passo 4, immagine 1 di 1
    • Using a Phillips #0 screwdriver, unscrew the five 4.3mm screws attaching the battery to the computer.
  5. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: passo 5, immagine 1 di 1
    • Remove the battery by pulling it directly towards you.
  6. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement, Speakers: passo 6, immagine 1 di 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement, Speakers: passo 6, immagine 2 di 2
    • Use a Phillips #0 screwdriver to remove the four 4.6mm screws holding the speakers.
    • Each speaker has 2 screws.
  7. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: passo 7, immagine 1 di 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: passo 7, immagine 2 di 2
    • Disconnect the wire running from the right speaker to the motherboard.
  8. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: passo 8, immagine 1 di 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: passo 8, immagine 2 di 2
    • Remove the tape that is holding down the wire that connects the two speakers.
  9. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: passo 9, immagine 1 di 1
    • Remove the speakers by lifting them directly upward.
Conclusione
Eevee Murdock
Membro da: 01/23/20
1.086 Reputazione
6 Guide realizzate
Cal Poly, Team S18-G4, White Winter 2020 Membro di Cal Poly, Team S18-G4, White Winter 2020
CPSU-WHITE-W20S18G4
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 27
Tutti i Tempi: 1,007
