Salta al contenuto principale
Lenovo ThinkPad W541 Touchpad Replacement
Cosa ti serve
  1. Lenovo ThinkPad W541 Touchpad Replacement, Touchpad: passo 1, immagine 1 di 2 Lenovo ThinkPad W541 Touchpad Replacement, Touchpad: passo 1, immagine 2 di 2
    • Slide the clips to the left and right sides, remove the battery upwards.
    • Loosen two Phillips #00 screws and open the cover plate.
    • Remove four 9.0 mm Phillips #00 case screws.
    • Remove three 9.0 mm Phillips #00 screws circled with red in the second picture.
  2. Lenovo ThinkPad W541 Touchpad Replacement: passo 2, immagine 1 di 3 Lenovo ThinkPad W541 Touchpad Replacement: passo 2, immagine 2 di 3 Lenovo ThinkPad W541 Touchpad Replacement: passo 2, immagine 3 di 3
    • Use the pry bar to push the keypad below the slot shown in the first picture and push it upward.
    • Loosen six Phillips #000 screws circled with red in the second picture, lift up the keyboard.
  3. Lenovo ThinkPad W541 Touchpad Replacement: passo 3, immagine 1 di 3 Lenovo ThinkPad W541 Touchpad Replacement: passo 3, immagine 2 di 3 Lenovo ThinkPad W541 Touchpad Replacement: passo 3, immagine 3 di 3
    • Open the black clips according to the direction marked in the first picture and remove the cable.
    • Use a pry bar to pry open the black protective casing upwards.
    • Follow the direction shown in the third picture, open the black clips upwards and remove the cable.
  4. Lenovo ThinkPad W541 Touchpad Replacement: passo 4, immagine 1 di 3 Lenovo ThinkPad W541 Touchpad Replacement: passo 4, immagine 2 di 3 Lenovo ThinkPad W541 Touchpad Replacement: passo 4, immagine 3 di 3
    • Remove the four 2.0 mm Phillips #000 screws circled with red in the first picture.
    • Carefully remove the metal tape shown in the second picture and paste it back on after replacing the new touchpad.
    • As shown in the third picture, remove the trackpad that needs to be replaced.
  5. Lenovo ThinkPad W541 Touchpad Replacement: passo 5, immagine 1 di 1
    • You can replace your touchpad with a new one. To install your computer just follow this guide in reverse.
Conclusione
Panaien Liu
Membro da: 01/31/23
121 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 14
Tutti i Tempi: 383
