Salta al contenuto principale
Lenovo ThinkPad W540 RAM Replacement
Cosa ti serve
  1. Lenovo ThinkPad W540 RAM Replacement, RAM: passo 1, immagine 1 di 2 Lenovo ThinkPad W540 RAM Replacement, RAM: passo 1, immagine 2 di 2
    • Flip your laptop to the bottom so that the backplate is shown.
    • Unscrew the captive screws on the backplate with a Phillips #0 screwdriver.
    • The screws should hold to the backplate so you shouldn’t worry about losing them.
  2. Lenovo ThinkPad W540 RAM Replacement: passo 2, immagine 1 di 2 Lenovo ThinkPad W540 RAM Replacement: passo 2, immagine 2 di 2
    • Locate the two latches that hold the RAM stick into the laptop, and push them away from the stick.
    • After pushing on the latches, the RAM stick should lift up at an angle.
  3. Lenovo ThinkPad W540 RAM Replacement: passo 3, immagine 1 di 1
    • Safely push forward the RAM stick away from the slot, and remove the stick entirely.
Conclusione
Nana A
Membro da: 11/01/23
97 Reputazione
1 Guida realizzata
UMass Dartmouth, Team 3-2, Konn Fall 2023 Membro di UMass Dartmouth, Team 3-2, Konn Fall 2023
UMASSD-KONN-F23S3G2
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 14
Tutti i Tempi: 74
