Salta al contenuto principale
Lenovo ThinkPad W540 Display Replacement
Cosa ti serve
  1. Lenovo ThinkPad W540 Display Replacement, Display: passo 1, immagine 1 di 2 Lenovo ThinkPad W540 Display Replacement, Display: passo 1, immagine 2 di 2
    • Open your laptop so that the screen is at around a 180 degree angle.
    • Using a plastic opening tool, pry open the outer frame of the display.
    • Generally, it is best practice to start from the corner first, and then guide the opening tool around the the frame.
  2. Lenovo ThinkPad W540 Display Replacement: passo 2, immagine 1 di 2 Lenovo ThinkPad W540 Display Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #00 screwdriver to unscrew the four 3 mm screws holding the display, one for each corner.
    • Once unscrewed, flip the display over the other side of the laptop (keyboard end).
  3. Lenovo ThinkPad W540 Display Replacement: passo 3, immagine 1 di 2 Lenovo ThinkPad W540 Display Replacement: passo 3, immagine 2 di 2
    • Use a plastic spudger, safety lift the adhesive tape from the connector.
    • Do not disregard the tape from the connector entirely as you will be reusing it later.
    • This adhesive tape will be strong, remove the tape carefully to prevent damage to the display connector.
  4. Lenovo ThinkPad W540 Display Replacement: passo 4, immagine 1 di 1
    • Safely disconnect the display from the connector.
    • Although you can use your hands to disconnect the connector, it is recommended that you use a spudger instead.
Conclusione
Kevin Dang
Membro da: 10/30/23
333 Reputazione
2 Guide realizzate
UMass Dartmouth, Team 3-2, Konn Fall 2023 Membro di UMass Dartmouth, Team 3-2, Konn Fall 2023
UMASSD-KONN-F23S3G2
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 25
Tutti i Tempi: 101
