Introduzione
Follow this guide to remove the SSD/Hard Drive from your Lenovo Thinkpad T560.
The hard drive stores data in your computer.
Some symptoms of a bad hard drive are your computer freezing and/or slowing down, a blue screen appearing, unusual sounds coming from the laptop, and the computer’s data being corrupted. Some more information about a faulty hard drive can be found at this website.
Before removing/replacing the hard drive, make sure to disable the internal battery, turn off your laptop and disconnect it from any external power sources.
Cosa ti serve
Using the Phillips #0 screwdriver, remove the eight 7 mm screws holding the back panel to the T560.
Using the Phillips #0 screwdriver, remove the 3.5mm screw securing the SSD/Hard Drive.
Altre 2 persone hanno completato questa guida.
