Salta al contenuto principale
Lenovo ThinkPad T560 SSD/Hard Drive Replacement
Cosa ti serve
  1. Lenovo ThinkPad T560 SSD/Hard Drive Replacement, Back Panel: passo 1, immagine 1 di 1
    • Before you begin this guide, make sure to disable the internal battery, power down the device and disconnect from any external power sources.
    • The external battery should be removed prior to back panel disassembly however this device doesn't have one so we aren't able to show the process.
    • Using the Phillips #0 screwdriver, remove the eight 7 mm screws holding the back panel to the T560.
  2. Lenovo ThinkPad T560 SSD/Hard Drive Replacement: passo 2, immagine 1 di 1
    • Use the iFixit opening tool to pry the back panel off your T560.
    • Work your way around the perimeter of the device to undo the clips and detach the back panel.
  3. Lenovo ThinkPad T560 SSD/Hard Drive Replacement, SSD/Hard Drive: passo 3, immagine 1 di 1
    • Using the Phillips #0 screwdriver, remove the 3.5mm screw securing the SSD/Hard Drive.
  4. Lenovo ThinkPad T560 SSD/Hard Drive Replacement: passo 4, immagine 1 di 1
    • Pick up the SSD/Hard Drive and unplug it from the cable connecting the SSD/Hard Drive to the motherboard.
  5. Lenovo ThinkPad T560 SSD/Hard Drive Replacement: passo 5, immagine 1 di 1
    • Remove SSD/Hard Drive case from the drive.
Conclusione
Altre 2 persone hanno completato questa guida.
Clemson, Team 1-3, Hunter Spring 2022 Membro di Clemson, Team 1-3, Hunter Spring 2022
CLEM-HUNTER-S22S1G3
5 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 54
Ultimi 30 Giorni: 199
Tutti i Tempi: 4,316
