Introduzione
If the internal battery for your Lenovo Thinkpad T560 has gone bad and needs to be replaced, follow this guide. Note that the Lenovo Thinkpad T560 has two batteries: an internal battery and an external battery.
The most common reasons to why this component needs to be replaced are:
- The battery is failing to charge effectively
- The internal/external battery has gone bad
Before replacing the battery, make sure to power down the device and disconnect it from any external power sources.
Cosa ti serve
Using the Phillips #0 screwdriver, remove the eight 7 mm screws holding the back panel to the T560.
Disconnect the battery connector from the motherboard by pulling it out of the port.
Un commento
Is there any way to disable the battery whitelist or otherwise get the device to work with 'unauthorized' external batteries as OEM external batteries are no longer produced by Lenovo or sold by any vendor including ifixit itself? I've had some that worked for close to a year now up until yesterday, when the laptop suddenly decided they are no longer official.
