Salta al contenuto principale
Lenovo ThinkPad T500 Speaker Replacement
Cosa ti serve
  1. Lenovo ThinkPad T500 Speaker Replacement, Speaker: passo 1, immagine 1 di 1
    • Remove the eight 14mm screws using the Phillips #0 Screwdriver.
  2. Lenovo ThinkPad T500 Speaker Replacement: passo 2, immagine 1 di 1
    • Lift the palm rest panel up.
    • Be sure to lift the panel slowly; there is a ribbon cable attached to the bottom.
  3. Lenovo ThinkPad T500 Speaker Replacement: passo 3, immagine 1 di 1
    • Use the spudger to disconnect the ribbon cable.
  4. Lenovo ThinkPad T500 Speaker Replacement: passo 4, immagine 1 di 1
    • With the panel disconnected, lift the keyboard.
    • As with the panel, lift the keyboard slowly; there is a ribbon cable attached to the bottom.
  5. Lenovo ThinkPad T500 Speaker Replacement: passo 5, immagine 1 di 1
    • Disconnect the ribbon cable with the spudger.
  6. Lenovo ThinkPad T500 Speaker Replacement: passo 6, immagine 1 di 2 Lenovo ThinkPad T500 Speaker Replacement: passo 6, immagine 2 di 2
    • Remove the keyboard and the panel.
    • Using the Phillips #0 Screwdriver, remove the three 3 mm screws that are at the bottom sides and near the top-left of the speaker cover.
    • Disconnect the orange and blue cables next to the left side of the speaker cover.
  7. Lenovo ThinkPad T500 Speaker Replacement: passo 7, immagine 1 di 1
    • Remove the speaker cover by carefully pulling up and towards you.
  8. Lenovo ThinkPad T500 Speaker Replacement: passo 8, immagine 1 di 1
    • Remove the four 3mm screws on the speakers with the Phillips #0 Screwdriver.
  9. Lenovo ThinkPad T500 Speaker Replacement: passo 9, immagine 1 di 2 Lenovo ThinkPad T500 Speaker Replacement: passo 9, immagine 2 di 2
    • Using the spudger, lift the tape over the right speaker's wires.
    • Although the right speaker is unscrewed, it can't be removed from the laptop yet!
  10. Lenovo ThinkPad T500 Speaker Replacement: passo 10, immagine 1 di 2 Lenovo ThinkPad T500 Speaker Replacement: passo 10, immagine 2 di 2
    • Detach the blue and orange cables from the left speaker's clamps.
  11. Lenovo ThinkPad T500 Speaker Replacement: passo 11, immagine 1 di 3 Lenovo ThinkPad T500 Speaker Replacement: passo 11, immagine 2 di 3 Lenovo ThinkPad T500 Speaker Replacement: passo 11, immagine 3 di 3
    • Locate the plug in the middle of the laptop that connects both the left and right speakers.
    • Use the spudger to unplug the speaker wires.
  12. Lenovo ThinkPad T500 Speaker Replacement: passo 12, immagine 1 di 1
    • Remove the speakers.
Conclusione
nicO
Membro da: 04/14/15
15.927 Reputazione
88 Guide realizzate
Global Fixers Membro di Global Fixers
Community
34 Membri
597 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,227
