Salta al contenuto principale
Lenovo ThinkPad T490s Battery Cable Disconnect
Solo Prerequisita
Questa guida è destinata a essere usata solo come prerequisito per altre guide. Da sola è incompleta.
Cosa ti serve
  1. Lenovo ThinkPad T490s Battery Cable Disconnect, Loosen the back screws: passo 1, immagine 1 di 2 Lenovo ThinkPad T490s Battery Cable Disconnect, Loosen the back screws: passo 1, immagine 2 di 2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use your Phillips #1 screwdriver to fully loosen the five screws on the back cover.
    • These screws are captive—they won't come out after being unscrewed.
  2. Lenovo ThinkPad T490s Battery Cable Disconnect, Release the clips: passo 2, immagine 1 di 2 Lenovo ThinkPad T490s Battery Cable Disconnect, Release the clips: passo 2, immagine 2 di 2
    • Orient your laptop so that the screen's silver hinges are closest to you.
    • Insert an opening pick between the back cover and the device body near a hinge corner.
    • Pry upward to release the clips holding the cover. Listen for a loud click when each clip releases.
  3. Lenovo ThinkPad T490s Battery Cable Disconnect: passo 3, immagine 1 di 2 Lenovo ThinkPad T490s Battery Cable Disconnect: passo 3, immagine 2 di 2
    • Insert your opening pick between the cover and the device body at the other hinge corner.
    • Pry upward to release additional retaining clips.
  4. Lenovo ThinkPad T490s Battery Cable Disconnect, Remove the back cover: passo 4, immagine 1 di 3 Lenovo ThinkPad T490s Battery Cable Disconnect, Remove the back cover: passo 4, immagine 2 di 3 Lenovo ThinkPad T490s Battery Cable Disconnect, Remove the back cover: passo 4, immagine 3 di 3
    • Grab the front edge of the cover and lift it away from you.
    • There may be additional clips holding the cover in place. These remaining clips will release easily as you remove the cover.
  5. Lenovo ThinkPad T490s Battery Cable Disconnect, Disconnect the battery cable: passo 5, immagine 1 di 2 Lenovo ThinkPad T490s Battery Cable Disconnect, Disconnect the battery cable: passo 5, immagine 2 di 2
    • Grab the battery pull-tab at the head of the connector.
    • Pull the connector out of its socket in the direction of the cable.
Conclusione
Clay Eickemeyer
Membro da: 09/19/22
81.788 Reputazione
455 Guide realizzate
Guide Team Membro di Guide Team
Staff
9 Membri
11.419 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 20
