Salta al contenuto principale
Lenovo ThinkPad T470S Wi-Fi Card Replacement
Cosa ti serve
  1. Lenovo ThinkPad T470S Wi-Fi Card Replacement, Bottom Panel: passo 1, immagine 1 di 1
    • Use a Phillips #000 screwdriver to remove the five 7 mm screws from the bottom of the laptop.
    • Lift the bottom panel up and off the laptop.
  2. Lenovo ThinkPad T470S Wi-Fi Card Replacement, Wi-Fi Card: passo 2, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove the single 2.9 mm screw securing the Wi-Fi card.
    • The Wi-Fi card will lift to a slight angle after the screw is removed.
  3. Lenovo ThinkPad T470S Wi-Fi Card Replacement: passo 3, immagine 1 di 1
    • Grip the Wi-Fi card on both sides, then pull it directly out of its port.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 35
Tutti i Tempi: 1,042
