Introduzione
The hard drive is primarily used for the Lenovo ThinkPad T440p’s storage. If your computer is slow, it most likely needs replacing. The replacement is simple and will only require unscrewing screws and using a spudger to lift the hard drive out.
Cosa ti serve
Use a Phillips #1 screwdriver to remove the two 9mm screws holding the back cover.
Use a Phillips #0 screwdriver to remove one screw holding the hard drive.
Altre 7 persone hanno completato questa guida.
