Introduzione
The back cover is the protective layer for your computer that covers many components that will likely be replaced. The process is very simple and you will only need to remove two screws with a Phillips #1 screw driver.
Cosa ti serve
Use a Phillips #1 screwdriver to remove the two 9mm screws holding the back cover.
