Salta al contenuto principale
Lenovo ThinkPad T431S Hard Drive Replacement
Cosa ti serve
  1. Lenovo ThinkPad T431S Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 3 Lenovo ThinkPad T431S Hard Drive Replacement, Hard Drive: passo 1, immagine 2 di 3 Lenovo ThinkPad T431S Hard Drive Replacement, Hard Drive: passo 1, immagine 3 di 3
    • Remember before starting any disassembly, to prevent electric shock or harm, disconnect the laptop from any external power source and make sure device is powered off.
    • Use a Phillips #1 screwdriver to remove the eight 5.0 mm screws from the panel.
    • After loosening the screws, use the three opening tools to take the back panel off of the rest of the device.
  2. Lenovo ThinkPad T431S Hard Drive Replacement: passo 2, immagine 1 di 3 Lenovo ThinkPad T431S Hard Drive Replacement: passo 2, immagine 2 di 3 Lenovo ThinkPad T431S Hard Drive Replacement: passo 2, immagine 3 di 3
    • Remove the single 3 mm screw holding hard drive bracket in place.
    • Grasp the hard drive and remove it from its bracket.
    • Use a slight wiggle motion to carefully disconnect it from the front prong.
Conclusione
Altre 2 persone hanno completato questa guida.
Un commento
Can I add SSD without removing HDD? in Lenovo T431s?
Usama Khan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 16
Tutti i Tempi: 740
