Salta al contenuto principale
Lenovo ThinkPad T431S Fan Replacement
Cosa ti serve
  1. Lenovo ThinkPad T431S Fan Replacement, Fan: passo 1, immagine 1 di 2 Lenovo ThinkPad T431S Fan Replacement, Fan: passo 1, immagine 2 di 2
    • Remember before starting any disassembly, to prevent electric shock or harm, disconnect from any external power source and make sure device is powered off.
    • Use a Phillips #1 screwdriver bit to remove eight 5.0 mm screws from the back panel.
    • Carefully pry off the back panel using the opening tool.
  2. Lenovo ThinkPad T431S Fan Replacement: passo 2, immagine 1 di 2 Lenovo ThinkPad T431S Fan Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #1 screwdriver bit and remove the four 3.0 mm screws from the heatsink.
  3. Lenovo ThinkPad T431S Fan Replacement: passo 3, immagine 1 di 3 Lenovo ThinkPad T431S Fan Replacement: passo 3, immagine 2 di 3 Lenovo ThinkPad T431S Fan Replacement: passo 3, immagine 3 di 3
    • Disconnect the cable attached to the fan, pulling the connector straight down.
    • Lift and remove the fan.
Conclusione
Altre 2 persone hanno completato questa guida.
Un commento
Well done. I will have a go at fixing the fan on my T430s now that I’ve seen how easy it is to do.
Jocko - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 6
Tutti i Tempi: 328
