Salta al contenuto principale
Lenovo ThinkPad T431S Charging Port Replacement
Cosa ti serve
  1. Lenovo ThinkPad T431S Charging Port Replacement, Charging Port: passo 1, immagine 1 di 2 Lenovo ThinkPad T431S Charging Port Replacement, Charging Port: passo 1, immagine 2 di 2
    • Remember before starting any disassembly, to prevent electric shock or harm, disconnect from any external power source and make sure device is powered off.
    • Use a Phillips #1 screwdriver bit to remove eight 5.0 mm screws from the back panel.
    • After loosening the screws, use the three opening tools to take the back panel off of the rest of the device.
  2. Lenovo ThinkPad T431S Charging Port Replacement: passo 2, immagine 1 di 2 Lenovo ThinkPad T431S Charging Port Replacement: passo 2, immagine 2 di 2
    • Unscrew the single, 3.0 mm screw with a Phillips #1 screwdriver bit that holds the charging port housing into place.
  3. Lenovo ThinkPad T431S Charging Port Replacement: passo 3, immagine 1 di 2 Lenovo ThinkPad T431S Charging Port Replacement: passo 3, immagine 2 di 2
    • Remove the small, white connector cable by prying it from the connector with a plastic opening tool.
    • Remove the charging port assembly.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 22
Tutti i Tempi: 4,188
