Salta al contenuto principale
Lenovo ThinkPad T430s RAM Stick Replacement
Cosa ti serve
  1. Lenovo ThinkPad T430s RAM Stick Replacement, Battery: passo 1, immagine 1 di 3 Lenovo ThinkPad T430s RAM Stick Replacement, Battery: passo 1, immagine 2 di 3 Lenovo ThinkPad T430s RAM Stick Replacement, Battery: passo 1, immagine 3 di 3
    • Flip your ThinkPad on its back.
    • In the bottom left corner of your ThinkPad, slide the lever to the left. Hold the lever there.
    • Use your other hand to lift the battery up by prying the notch to the left of the lever.
    • Tilt the battery up and remove it from the ThinkPad.
  2. Lenovo ThinkPad T430s RAM Stick Replacement, RAM Stick: passo 2, immagine 1 di 3 Lenovo ThinkPad T430s RAM Stick Replacement, RAM Stick: passo 2, immagine 2 di 3 Lenovo ThinkPad T430s RAM Stick Replacement, RAM Stick: passo 2, immagine 3 di 3
    • With the Phillips #0 screwdriver, loosen the two 30 mm screws holding down the RAM stick plate.
    • Pry up the plate and set it aside.
  3. Lenovo ThinkPad T430s RAM Stick Replacement: passo 3, immagine 1 di 3 Lenovo ThinkPad T430s RAM Stick Replacement: passo 3, immagine 2 di 3 Lenovo ThinkPad T430s RAM Stick Replacement: passo 3, immagine 3 di 3
    • Use the pointy end of the spudger to bend the bars holding the RAM stick in place.
    • Lift the RAM stick up and out of the stick holder.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 24
Tutti i Tempi: 754
