Salta al contenuto principale
Lenovo ThinkPad T420s Thermal Paste Replacement
Cosa ti serve
  1. Lenovo ThinkPad T420s Thermal Paste Replacement, Opening the laptop.: passo 1, immagine 1 di 3 Lenovo ThinkPad T420s Thermal Paste Replacement, Opening the laptop.: passo 1, immagine 2 di 3 Lenovo ThinkPad T420s Thermal Paste Replacement, Opening the laptop.: passo 1, immagine 3 di 3
    • Remove all the visible screws and the battery.
    • Use a prying tool to remove the keyboard.
    • Unscrew the palmrest and disconnect all connectors.
  2. Lenovo ThinkPad T420s Thermal Paste Replacement, The insides.: passo 2, immagine 1 di 2 Lenovo ThinkPad T420s Thermal Paste Replacement, The insides.: passo 2, immagine 2 di 2
    • Unscrew the display assembly and remove it.
    • Unscrew the mother board and remove it.
  3. Lenovo ThinkPad T420s Thermal Paste Replacement, Changing the thermal paste and cleaning the fan: passo 3, immagine 1 di 3 Lenovo ThinkPad T420s Thermal Paste Replacement, Changing the thermal paste and cleaning the fan: passo 3, immagine 2 di 3 Lenovo ThinkPad T420s Thermal Paste Replacement, Changing the thermal paste and cleaning the fan: passo 3, immagine 3 di 3
    • Remove the screws that hold the cooling assembly and disconnect the fan.
    • Now is a good idea to upgrade the RAM.
    • Clean the old thermal paste both from the cooler and the CPU. It is best to use isopropyl alcohol and cotton swabs or paper towel, but be careful not to go too hard on the CPU.
    • You can also disassemble the fan and clean it from the inside.
    • It is also recommended to use compressed air to remove any dust in the laptop and the fan.
    • Dont use too much thermal paste, just enough to cover some portion of the pad. If you have a spreader, use it. The thermal paste will apply evenly after you tighten the heatsink.
    • Last, put the heatsink back carefully and tighten the screws in order to ensure even pressure. Dont forget to plug in the fan cable.
Conclusione
Altre 2 persone hanno completato questa guida.
Simeon Brankov
Membro da: 11/08/20
7.153 Reputazione
54 Guide realizzate
Un commento
how do i take off plate in between 1 and 2
Nuclear Fox - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 36
Ultimi 30 Giorni: 88
Tutti i Tempi: 2,784
