Salta al contenuto principale
Lenovo ThinkPad T410s Palm-rest Replacement
Cosa ti serve
  1. Lenovo ThinkPad T410s Palm-rest Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the laptop over.
    • Push and hold the locking switch to the left.
    • Pull the battery out with your other hand.
  2. Lenovo ThinkPad T410s Palm-rest Replacement, RAM: passo 2, immagine 1 di 2 Lenovo ThinkPad T410s Palm-rest Replacement, RAM: passo 2, immagine 2 di 2
    • Remove the single Phillips #0 screw grin the back panel.
    • Pull the back panel off.
  3. Lenovo ThinkPad T410s Palm-rest Replacement: passo 3, immagine 1 di 3 Lenovo ThinkPad T410s Palm-rest Replacement: passo 3, immagine 2 di 3 Lenovo ThinkPad T410s Palm-rest Replacement: passo 3, immagine 3 di 3
    • Pull the metal prongs at the side of the RAM away from each other.
    • The RAM will pop out of its socket when done correctly.
    • Pull the RAM out.
  4. Lenovo ThinkPad T410s Palm-rest Replacement, Keyboard: passo 4, immagine 1 di 1
    • Remove the Flathead 2.5mm screw.
  5. Lenovo ThinkPad T410s Palm-rest Replacement: passo 5, immagine 1 di 2 Lenovo ThinkPad T410s Palm-rest Replacement: passo 5, immagine 2 di 2
    • Wedge the flat end of a spudger, or plastic opening tool, under the end of the keyboard and pry up.
  6. Lenovo ThinkPad T410s Palm-rest Replacement: passo 6, immagine 1 di 2 Lenovo ThinkPad T410s Palm-rest Replacement: passo 6, immagine 2 di 2
    • Slide the keyboard out of the way until you can see what's underneath it.
    • The keyboard is still attached with a ribbon cable so don't try to fully remove it.
  7. Lenovo ThinkPad T410s Palm-rest Replacement: passo 7, immagine 1 di 1
    • Use the flat end of a spudger to unplug the keyboard connector from the laptop.
    • Pull the keyboard out.
  8. Lenovo ThinkPad T410s Palm-rest Replacement, Palm-rest: passo 8, immagine 1 di 1
    • Remove the twelve Phillips #0 screws from the back panel.
  9. Lenovo ThinkPad T410s Palm-rest Replacement: passo 9, immagine 1 di 2 Lenovo ThinkPad T410s Palm-rest Replacement: passo 9, immagine 2 di 2
    • Up the flat end of a spudger to lift up the black tab on the ZIF connector.
    • Pull out the ribbon connector from the ZIF connector.
  10. Lenovo ThinkPad T410s Palm-rest Replacement: passo 10, immagine 1 di 2 Lenovo ThinkPad T410s Palm-rest Replacement: passo 10, immagine 2 di 2
    • Remove the palm rest from the laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 30
Tutti i Tempi: 1,444
